When inputting or selecting an A/B path, the pre-documented path with the same source/destination will be displayed on the intelligence dialog, where you can view the pre-documented path results and draw its path map.
1.Click Path on the search bar.
2.Enter the source and the destination IP addresses (device hostnames or DNS names).
