1.Enter one of the following search terms in the search bar:
▪dashboard name
▪device hostname
2.Press the Enter key on your keyboard to start searching. The search results are displayed under the Dashboard group with the matched keyword highlighted.
▪Using Dashboard to Visualize Multi-Dimensional Data
