Review the Triggered Map Result
Follow the steps below to review the triggered map result:
1.In Splunk Enterprise, navigate to Search & Reporting.
2.Search with the following search query and a time range that covers the alert triggering time.
index=_internal sourcetype=splunkd "Map URL ----- Neighbor"
3.(Optional) For easy access next time, save this search as a report and create a NetBrain dashboard.
Keywords for All Supported Map Types
Map Type
Keyword
NetBrain Automation - Device
NetBrain Automation - Multi-Device
Map URL ----- Multi_devices
NetBrain Automation - Site
Map URL ----- Site
NetBrain Automation - Path
Map URL ----- Path
NetBrain Automation - ACI
Map URL ----- Context
NetBrain Automation - Existing Map
Map URL ----- Existing
