Learn map tools and keyboard shortcuts to become a pro at NetBrain maps.
Click Map on the map toolbar to open the toolbox.
Tool Icon |
Function |
Shortcut |
Undo |
Ctrl + Z |
Redo |
Ctrl + Y |
Ctrl + P |
Select Mode Free-hand Select: The default mode. You can click the desired map objects and adjust them at will. Area Select: Select map objects by dragging your mouse to select an area. |
N/A |
See Locking a Map for more details. |
N/A |
Category |
Action |
Shortcut |
Select map objects |
Select multiple map objects |
Hold the Ctrl key while selecting map objects. |
Bulk select map objects by object type, such as sites or devices belonging to the same device type. |
Hold the Shift key while selecting a map object belonging to the target type. |
Select map objects by area |
Hold the left mouse button for 2 seconds at least, and then select an area. |
Select all objects on a map |
Ctrl + A |
Alignment |
Align the selected map objects to the left |
Alt + L |
Align the selected map objects to the center |
Alt + C |
Align the selected map objects to the right |
Alt + R |
Align the selected map objects to the top |
Alt + T |
Align the selected map objects to middle |
Alt + M |
Align the selected map objects to the bottom |
Alt + B |
Zoom Controls |
Zoom in |
Rotate the mouse wheel button forward. |
Zoom out |
Rotate the mouse wheel button backward. |
Move map objects |
Move the whole map |
Drag your mouse while holding the left mouse button, or press the Arrow key (↑↓←→). |
Move specific objects |
Selecting the objects, and then press the Arrow key (↑↓←→) or drag the objects with the mouse. Tip: To finely move map objects, select them and then press Alt + Arrow keys (↑↓←→) after selecting them. |
Others |
Undo |
Ctrl + Z |
Redo |
Ctrl + R |
Print a map |
Ctrl + P |
Save a map |
Ctrl + S |
