You can browse and manage all NI through the Folder View in the NI pane on the left side of the Map, including essential addition, deletion, modification, check operations, and the Folder NI context menu.
1.Open a map and navigate to the Intent pane. By default, all the network intents are displayed in List View.
2.Click the switch icon to view the network intent in Folder View.
3.The basic operations in Folder context are as follows:
Note: For more information to install an NI as triggered automation or recommended automation, see Install Triggered Automation and Install Recommended Automation.
