Follow the steps below to debug using respective logs:
1.In Splunk Enterprise, navigate to Search & Reporting.
2.Search with the following search queries and a time range that covers the alert triggering time.
•Use the query below to search for splunkd service logs. NetBrain App logs are included as well.
oindex=_internal sourcetype=splunkd
•Add the following keywords into the query above to filter specific logs.
| Map Type | Keyword |
| NetBrain Automation - Device | Neighbor map response |
| NetBrain Automation - Multi-Device | Multi_devices map response |
| NetBrain Automation - Site | Site map response |
| NetBrain Automation - Path | Path map response |
| NetBrain Automation - ACI | Context map response |
| NetBrain Automation - Existing Map | Existing map response |
