Usage Report records the login details of system users, such as first login time, last logout time, and total online time.
To export the usage report, do the following:
2.In the System Management page, select the Usage Report tab. The user accounts who have logged in to the system within the specified time period are listed.
Tip: The Total Online Time is not simply the sum of logged-in time duration that the user spends in the system. If the user has logged in to multiple domains concurrently, the overlapping time contributes to the total online time only once.
3.Click Export to export the usage report. The default location of the exported file is C:\Users\<your username>\Downloads.
Tip: To browse the detailed user login records, click Check Details in the corresponding entry. The usage details can also be exported by clicking the
icon in the pop-up dialog.
