Enabling/Disabling Installed Automations
1.Click ,scroll down and select Proactive Automation Manager from the menu.
2.Navigate to Triggered Intent tab, check/ uncheck to enable or disable installed triggered intent(s).
Note: If the installed triggered intent is disabled, it will not be displayed in Execution Tree.
