Each device has a system built-in image so as to show its main physical appearance in the system.
To add more images or customize images, do the following:
1.In the Device Details pane, click the image at the upper-left corner.
2.Click Edit.
Tip: The supported formats of image files are .bmp, .jpg, and .png.
Note: It's not allowed to delete system built-in images or apply system built-in images to other devices.
▪Opening the Device Details pane
