In a data view template definition, device/interface highlights can be added to address configuration or other design differences among qualified devices.
The following table lists the properties of a device highlight.
Property |
Highlight Node by Variables |
Select a variable to use it to highlight qualified traditional devices or SDN nodes on a map. |
Display Highlight When |
Set a condition to control when to display this device highlight. ▪The default value - Always, indicating this highlight will be displayed under any circumstances. ▪If you select an option variable as a condition, then the highlight will be only displayed when the value of the selected variable is: oNon-empty (for string type) oNot equal to 0 (for number type) oequal to true (for boolean type) Note: Both device-level variables and input variables in the supporting variable list of the current data view template can be selected to define the display conditions for device highlights. Note: Table-type and list-type variables cannot be used as conditions. |
Legend |
The legend displayed on a map is to illustrate this device highlight. |
Color |
Customize a color for the device highlight. The default value is Random Color. |
The following table lists the properties of an interface highlight.
Property |
Highlight Interface by Variable |
Select a variable to use it to highlight interfaces of qualified traditional devices or SDN nodes on a map. |
Set a condition to control when to display this interface highlight. ▪The default value - Always Display, indicating this highlight will be displayed under any circumstances. ▪If you select an option variable as a condition, then the highlight will be only displayed when the value of the selected variable is: oNon-empty (for string type) oNot equal to 0 (for number type) oequal to true (for boolean type) Note: Only interface-level variables in the supporting variable list of the current data view template can be selected to define the display conditions for interface highlights. Note: Table-type and list-type variables cannot be used as conditions. |
Legend |
The legend displayed on a map is to illustrate the interface highlight. |
Color |
Customize a color for the interface highlight. The default value is Random Color. |
Line Style |
Select a line style for the interface highlight. |
Line Width |
Select a line width for the interface highlight. |
