To adapt to various abbreviated commands that you may type in, Smart CLI predefines a list of full commands and also allows you to define full commands. Each abbreviated command can be mapped, and the corresponding full command will be used for data retrieval and data storage.
Complete the following steps to define a new full command.
1.Click Network Setting > Full Command Definition in the Smart CLI.
2.In the Full Command Definition dialog, click New to add a new full command in the current tenant.
1)Enter a new full command in the Command field.
2)Select a mode for the command.
3)Select device types to apply the command. Click OK.
3.Click Close.
