By default, devices on each map page are displayed in the default data view.
Tip: To update default data view with the latest data saved in the database, you can configure through a scheduled benchmark task. See Updating Default Data View for more details.
The following table lists the default data units in each device position.
Position  |
Device Data Unit  |
Position1  |
Management IP  |
Position2  |
NULL  |
Position3  |
NULL  |
Position4  |
NULL  |
Note: If the value of a data unit is null, it will not be displayed in the specified position.
The following table lists the default data units on each interface position for different topology types.
Position  |
Interface Data Unit  |
IPv4 L3 Topology   |
IPv4 L3 Topology   |
IPv6 L3 Topology  |
L2 Topology  |
Position1  |
Routing Protocol  |
Unnumbered IP  |
Link-local  |
Mode  |
Position2  |
NULL  |
Routing Protocol  |
IPv6 Routing Protocol  |
Trunk Encapsulation  |
Position3  |
Multicasting Mode  |
Multicasting Mode  |
Multicasting Mode  |
Speed  |
Position4  |
MPLS VRF  |
MPLS VRF  |
MPLS VRF  |
Duplex  |
Position5  |
Inbound ACL  |
Inbound ACL  |
Inbound ACL  |
Access Vlan  |
Position6  |
Outbound ACL  |
Outbound ACL  |
Outbound ACL  |
Native Vlan  |
Position7  |
Description  |
Description  |
Description  |
Description  |
Position8  |
NULL  |
NULL  |
NULL  |
NULL  |
