The following table lists the interface properties/attributes (case-sensitive).
Property Name |
Display Name in Device Details Pane |
name |
Interface Name |
The name of an interface. |
ips |
IPv4 Address |
The IPv4 address of an interface. |
ipv6s |
IPv6 Address |
The IPv6 address of an interface. |
ipv6LinkLocalAddress |
IPv6 Link Local Address |
The IPv6 local address of an interface. |
mibIndex |
MIB Index |
The MIB index of an interface. |
bandwidth |
Bandwidth |
The bandwidth of an interface. |
speed |
Speed |
The speed of an interface. |
duplex |
Duplex |
The duplex of an interface. |
intfStatus |
Live Status |
The state of an interface. |
macAddr |
MAC Address |
The MAC address of an interface. |
moduleSlot |
Slot# |
The module slot number of an interface. |
moduleType |
Module Type |
The module type of an interface. |
descr |
The description of an interface. |
routingProtocol |
Routing Protocol |
The routing protocol configured on an interface. |
multicastMode |
Multicasting Mode |
The multicasting mode of an interface. |
mplsVrf |
MPLS VRF |
The name of the VRF configured on an interface. |
mplsVpn |
MPLS VPN |
The MPLS VPN configured on an interface. |
inAclName |
Inbound ACL |
The inbound ACL of an interface. |
outAclName |
Outbound ACL |
The outbound ACL of an interface. |
mode |
Switchport Mode |
The switch port mode of an interface. |
vlan |
VLAN |
The VLAN number that an interface belongs to. |
trunkNativeVlan |
Native VLAN |
The native VLAN of an interface as switch port. |
trunkEncapsulation |
Trunk Encapsulation |
The trunk encapsulation protocol of an interface as a trunk port. |
ipUnnumberedIp |
Trunk Unnumbered IP |
The unnumbered IP address of an interface as an unnumbered interface. |
