1.Install the network intent(s) into the probe(s).
1)There are different methods you can use to install the network intent(s) into the probe(s):
•Hover over the end point of the probe, then click
•Hover over the interested probe, click
and select Add Intent
•Using Install Network Intent :
2)In the Triggered Automation Details window, click +Add.
Note: If using install Network Intent, you also need to manually select the Target Probe.
3)Select the network intent in the Select Network Intent window and click OK.
