The data retrieved by the Schedule CLI commands is stored in Front Server Data Engine. Massive amounts of data will be retrieved and stored after long term use. To optimize the system performance, you can configure the following auto clean CLI command result data settings in Domain Management> Operations>Domain Settings>Global Data Clean Settings> Front Server DB Data.
On the same page, you can also choose to delete data manually.
