Follow the steps below to add NetBrain alert action to a Splunk Alert:
1.Open an alert.
2.Click Edit to open the edit panel.
3.Click +Add Actions.
4.Select NetBrain Automation - Device.
5.Fill out the NetBrain Automation - Device Alert Action form.
•Tenant Name/Domain Name: NetBrain Tenant/Domain Name
•Splunk token is supported to pass alert data as variables in the Alert Action.
•Example:
oAlert Data Sample
"device":"US-BOS-SW1",
"Message":"This is a sample event message."
oToken Syntax
▪$result.device$
6.Click Save.
Note: The setting or trigger parameters in Splunk alert action will overwrite the same parameters in the NetBrain API Stub setting. The rest of the API Stub setting will remain.
