After discovering devices, you can view the devices with issues in the Domain Manager and resolve them to maintain your domain assets up-to-date. The domain manager summarizes devices by category and provides quick access to resolve issues. The device list in each category is updated as soon as a discovery task is finished, including both the on-demand discovery and the scheduled discovery.
There are the following categories in the Domain Manager. You can select any one to view, edit or solve issues for domain maintenance.
▪Unknown IP — the IP addresses that cannot be accessed via Telnet/SSH and SNMP during a discovery.
▪Discovered Devices — the devices discovered successfully during a discovery.
▪Missed Devices — the devices existing in the current domain but failed to be verified during a discovery.
▪Discovered by SNMP — the devices accessed by SNMP but failed to be accessed via SSH/Telnet.
▪Unknown SNMP sysObjectID — the devices whose sysObjectIDs are not defined in the Vendor Model table.
▪Unclassified Network Devices — the devices whose types are not supported, or not recognized due to unknown sysObjectIDs.
▪MPLS Cloud — used to enable A-B path across a vendor supplied MPLS network.
▪Resolving Duplicated IP and Subnet
