You can verify application paths in a runbook and run Qapps, CLI command, or other automation to troubleshoot upon path changes.
Note: The steps below assume that you have had the basic knowledge of NetworkBrain Runbook function.
1.On a map, open a runbook and add a Verify Application node to the runbook.
2.Click the Verify Application node and add the application paths.
3.Click Run to calculate and verify the paths.
4.Right-click a verified path with changes and draw the path on a map.
5.Add Qapps or other actions that you want to run for the application paths.
