Note: If you install Web Server and Web API Server on the same machine, both of them will be uninstalled after you run the above steps. To only uninstall Web Server, you need to open the Installation Wizard in the installation package and clear the Web Server check box.
1.Click the Windows start menu and then click the icon to open the Apps pane.
2.Right-click the Uninstall NetworkBrain Integrated Edition app in the pane, and then select Run as administrator from the drop-down list to launch the Installation Wizard.
3.Select the Delete all user data check box to delete all registry information and files under its installation path, and click Uninstall.
4.Click Finish to exit the Installation Wizard.
