Note: If you install Web Server and Web API Server on the same machine, both of them will be uninstalled after you perform the following steps.
1.Click the Windows start menu and then click the
icon to open the Apps pane.
2.Right-click the Uninstall NetworkBrain Integrated Edition app in the pane, and then select Run as administrator from the drop-down list to launch the Installation Wizard.
4.Click Finish to exit the Installation Wizard.
