The system provides the Host and Cluster View to hierarchically displays the data centers, ESXi hosts, resource pools and virtual machines in a vCenter network.
2.Select ESXi from the Category list, and then select Hosts and Clusters from the View list.
3.Click a node and select the Device Details tab.
4.View the context maps of a node.
Example1: Context Maps for an ESXi Host node.
Example2: Context Maps for a VM node.
Tip: For more information about the vCenter context maps, see Context Maps of vCenter Nodes for details.
