The Qapp description refers to a summary of the basic information about a Qapp.
1.In the Qapp Editor, click the
icon on the Execution Flow tab. The Qapp description is displayed in the bottom pane.
2.Enter the required information in each field.
1)Enter a description to describe the Qapp in the Description field.
2)Enter a keyword in the Keyword field as a hint.
3)Enter the contact information in the Contact Info field.
3.In the Sample Picture field, click Import to select a sample map or a picture from your local folder to visually describe the Qapp.
