NetworkBrain Variable Intellisense
As mentioned in Inventory Template, inventory template can be defined by using customized variables provided by NetBrain. For example, a variable can be defined as: interface = $interface. _visible_ interface, where the latter $interface._visible_interface is the variable provided by NetBrain.
When you enter $ in the Inventory Template editor, there will be an IntelliSense dialog that prompts indicating which variables can be used.
The following variables are currently supported by NetworkBrain Variable Intellisense:
Variable Name
Description
$device.management_IP
IP address of the device.
$device.management_interface
Match with device property management_interface- data from DB_Domain.Device
$device.model
Model of the device.
$device.hostname
Host name of the device.
$device.serial_number
Serial number of the device.
$device.vendor
Vendor of the device. (E.g., Cisco)
$device.os_version
OS version of the device (E.g., ios)
$interface._all
All available interface names for each device.
$interface._visible
Interface name that represents the visible interface of the devices displayed on the map.
$interface.management_interface
$credential.username
*Username of SDN Controller or legacy network device.
$credential.password
*Password of SDN Controller or legacy network device.
$credential.enable_username
*Enable device username settings (shared or private) for SDN Controller of legacy network device.
$credential.enable_password
*Enable device password settings (shared or private) for SDN Controller of legacy network device.
$credential.SSH_port
The port for SSH access.
$credential.enable_cmd
Command used to enter device's enable mode.
$credential.quit_cmd
Command used to quit device's enable mode.
$sdn_controller.xxx
All SDN Controllers available in the tenant.
*Cross reference with access credential settings (Domain Management > Advanced Settings > Select Access Credential for Telnet/SSH CLI and Change Management).
