Monitoring Servers and Services
NetworkBrain Service Monitor provides a portal for administrators to observe the health of deployed Windows and Linux servers, with operations management of related services. It collects various types of metrics data from these deployed servers and visualizes them in tables or line charts.
With Service Monitor, system administrator can manage to troubleshoot a system-level issue and take remedial actions, or even optimize the system performance by performing the following operations:
Check the status and connectivity of each server, and the performance metrics of relevant services in the system, to troubleshoot a login failure, a search failure, or an automation task execution failure.
Analyze the trending data of system resource utilization metrics, such as CPU utilization, memory utilization, and disk/directory space usage.
Restart NetworkBrain services.
Use Flow
Note: If you deploy more than one system across multiple data centers, you will have more than one Service Monitor portal.
1.Install Service Monitor Agent.
2.Monitor Server and Service Metrics.
Monitored Data Type
The following table lists the data types that can be monitored via the Service Monitor Portal. All the metrics data is saved in Elasticsearch.
Collectable Data
Description
Server Metrics
The metrics data of all deployed servers, including:
Live connectivity (Connected/Disconnected).
Basic server information, such as hostname, IP address, and OS version.
System resource utilization metrics, such as CPU utilization, memory utilization, disk I/O, and disk storage.
The list of NetworkBrain services and third-party services installed on each of them.
Service Metrics
The metrics data of NetworkBrain services and third-party services installed on each deployed server, including:
Real-time status (Running/Stopped).
Basic service information, such as PID, startup type, version, uptime, and a number of threads.
Metrics data related to quality and performance. It may vary depending on service types. See Monitored Metrics for more details.
Cleaning Aged Data
Managing MongoDB Disk Alert Rules
