Follow the steps below to debug using respective logs:
1.In Splunk Enterprise, navigate to Search & Reporting.
2.Search with the following search queries and a time range that covers the alert triggering time.
•Use the query below to search for splunkd service logs. NetworkBrain App logs are included as well.
oindex=_internal sourcetype=splunkd
•Add the following keywords into the query above to filter specific logs.
Map Type |
Keyword |
NetworkBrain Automation - Device |
Neighbor map response |
NetworkBrain Automation - Multi-Device |
Multi_devices map response |
NetworkBrain Automation - Site |
Site map response |
NetworkBrain Automation - Path |
Path map response |
NetworkBrain Automation - ACI |
Context map response |
NetworkBrain Automation - Existing Map |
Existing map response |
