1.In your web browser, navigate to http(s)://<IP address or hostname of NetworkBrain Web Server>/. For example, https://10.10.3.141/ or http://10.10.3.141/.
2.In the login page, enter your username or email address, and password.
Note: If you are using SSO (Single Sign-On), click the hyperlink of the SSO server to redirect to the login page of your Identity Provider. After your credentials are verified, you will be directly logged in to the system and you can skip step 3.
Tip: To go to the administrator login page, click Administrator Login.
3.Click Log In. Please update the initial password if it's your first-time login.
4.Click the domain name from the quick access toolbar and select Domain Management.
Note: It is not recommended to use the same web browser to log in to the system with multiple user accounts. Only the last logged-in user can be recognized as the current user.
▪Logging in to Tenant Management Page
▪Logging in to System Management Page
