1.Extended key usage must permit both TLS client and TLS server authentication. 2.Both the certificate and the CA chain are required, because NetworkBrain requires a full chain certificate. 3.Only the Base-64 encoded X.509 (.CER) format is supported. 4.Private key cannot be password encrypted and must be in the pkcs8 format. |
Use a vi editor on Linux or Notepad++ on Windows to open your private key file, and make sure it looks exactly like this: -----BEGIN PRIVATE KEY----- If you see something like: -----BEGIN PRIVATE KEY----- It means this key is encrypted and must be decrypted first. openssl rsa -in ABCCompany.key -out ABCCompany.key.unencrypted |
For example, if your company has a root CA and an intermediate CA, which means Level 3 cert chain is used. You need to make sure there is 1 cert.pem file, 1 intermediate-ca.pem file and 1 root-ca.pem file. Each of them should look like: -----BEGIN CERTIFICATE----- You also need to consolidate/merge all the separate CA files into a chain-ca.pem file. To do so, copy and paste the BEGIN CERTIFICATE – END CERTIFICATE section into a single file using Notepad++ or VI Editor. The final chain-ca.pem file looks like: -----BEGIN CERTIFICATE----- |
▪The easiest way is to install Elasticsearch with SSL enabled. Note: HTTPS, which can be enabled on IIS of Web Server, is not covered here. ▪Another way is to check by running the following command on a Linux server: Note: This command cannot ensure the installation on NetworkBrain will be successful. [root@localhost pki-scripts]# openssl verify -verbose -CAfile ./ca/chain-ca.pem node.pem |
The most common certificate format is “.PFX”, which usually includes private keys and certificates in X.509 format. Use the following command to convert a PFX file, for example, pkcs12, into the one that NetworkBrain supports: openssl pkcs12 –in ABCCompany.pfx -out netbrain.pem –nodes During this converting process, you might be asked to input the passphrase of the PFX file. Check with your Network Administrator for more details. |
The best way to verify your certificate chain is to install Elasticsearch first. If the installation failed, check the elastic-search-cluster.log file under Elasticsearch’s installation directory to see if there is any error. Generally, an error might be caused by: ▪incorrect cert or private key format ▪extended key usage TLS client does not permit client auth. In these two cases, check with your CA server manager or IT staff to regenerate the required certificate chain and private key file. Note: Try the new certificate chain and key file to make sure the elastic-search-cluster.log file does not generate the same error logs anymore.
If the above FAQ cannot resolve your problem, please collect the whole logs folder under Elasticsearch installation directory and send to NetBrain Support Team.
[root@localhost home]# cd elasticsearch/
[root@localhost elasticsearch]# ls
bin config data fix_releaseinfo.json lib LICENSE.txt logs modules NOTICE.txt pid plugins README.textile temp
