To discover the public cloud resources, you will need to have the related API access to public cloud providers. The general steps for setting public cloud access are as follows:
1.Setting up API access: you will need to use either key-based access or role-based access method to discover public cloud resources.
2.Discover Public Cloud resources: run the discovery function with the specified accounts to discover the public cloud resources.
3.Setting up benchmark tasks: you will need to set up benchmark tasks to retrieve the public cloud resources periodically.
For the complete instruction on how to set up the API access and discover the public cloud resources, please refer to the following documents:
