By default, the logo image of NetworkBrain is displayed on the login page, and there is no banner.
To customize the logo and banner on the login page, do the followings:
1.Log in to the System Management Page.
2.In the System Management page, select the Advanced Settings tab.
3.In the Login Interface area, click Upload Logo.
Tip: To rollback to the default image, click Restore Defaults.
4.To add a link to the image so that users will be redirected to the webpage when they click the image, you need to enter a full URL. For example, https://www.netbraintech.com.
5.To add a login banner, select the Enable Login Banner check box.
1)Add a title.
2)Add a paragraph you want to display.
6.Click Save.
