The tuning options are effective for each device in the current domain wherever you tune live access for it.
Tuning Mode and Access Mode |
Options |
Auto Set Device Settings — overwrite the outdated access credentials in the Shared Device Settings with the correct credentials got by polling the credentials in the Network Settings. |
▪Management IP — overwrite Management IP addresses according to the interface type priority in the Live Access Settings if the system fails to access the Management IP in the Shared Device Settings. ▪Login Username/Password — overwrite the outdated Tenet/SSH login credentials in the Shared Device Settings. oPrivilege Username/Password — overwrite the login credentials of privileged mode in the Shared Device Settings. ▪SNMP Community — overwrite the SNMP community in the Shared Device Settings. ▪Lock Shared Device Settings if tuning succeeds — lock the access credentials in the Shared Device Settings for the successfully accessed devices, to protect the credentials from being changed during any live access activities (such as rediscovery). |
Verify Device Settings — only verify the credentials in Shared Device Settings without overwriting the outdated ones. |
▪Management IP — verify the Management IP in the Shared Device Settings. ▪Login Username/Password — verify the Tenet/SSH login credentials in the Shared Device Settings. oPrivilege Username/Password — verify the privilege login credentials in the Shared Device Settings. ▪SNMP Community — verify the SNMP community in the Shared Device Settings. |
Access Mode — specify an access method according to the configuration on your devices for the Auto Set Device Settings mode. |
▪Telnet Only — only use Telnet to access devices. ▪SSH Only — only use SSH to access devices. ▪Both Telnet and SSH — use Telnet and SSH to access devices. |
Field |
Management IP |
The IP address used to access the device in the tuning live access process. |
Management Interface |
The interface used to access the device in the tuning live access process. |
Ping |
Indicates whether the device can be accessed through the Ping command. ▪Succeeded — the system successfully accessed the device by ping. ▪Failed — the system failed in accessing the device by ping. |
SNMP RO |
The SNMP RO string used to access the device in the tuning process. |
SysObjectID |
The system object ID retrieved in the tuning process. |
Telnet/SSH |
Indicates whether Telnet/SSH is enabled on the device. ▪Succeeded — Telnet/SSH is enabled on the device. ▪Failed — Telnet/SSH is not enabled on the device. |
Login |
Indicates whether the system can log in to the device successfully. Auto Set Device Settings ▪Succeeded — the system logged in to the device with one of the Telnet/SSH login credentials in network settings. ▪Failed — the system cannot log in to the device with any of the Telnet/SSH login credentials in network settings. Verify Device Settings: ▪Succeeded — the system logged in to the device with the username/password pair in shared device settings. ▪Failed — the system cannot log in to the device with the username/password pair in shared device settings. |
Enable |
Indicates whether the system can enter the privileged mode of the device successfully. Auto Set Device Settings: ▪Succeeded — the system entered the privileged mode of the device with one of the privilege login credentials in network settings. ▪Failed — the system cannot enter the privileged mode of the device with any of the privilege login credentials in network settings. Verify Device Settings: ▪Succeeded — the system entered the privileged mode of the device with the privilege username/password pairs in shared device settings. ▪Failed — the system cannot enter the privileged mode of the device with one of the privilege username/password pairs in shared device settings. |
SNMP Hostname |
Indicates whether the hostname retrieved by SNMP is changed. ▪Unchanged — the hostname retrieved by SNMP is the same as the previous one. ▪New SNMP hostname — the hostname retrieved by SNMP has been changed. |
Vendor |
The vendor information retrieved via SNMP. |
Model |
The model information retrieved via SNMP. |
Front Server&Group |
The hostname of Front Server or the name of Front Server Group, which is used to access devices during the tuning process. |
Menu Option |
Operations |
Shared Device Settings |
Open the Shared Device Settings dialog box for the selected device. See Shared Device Settings for more details. |
Discover Selected IP |
Open the Discover tab page. See Discovering network Devices for more operations. |
Remove from Domain |
Remove the selected device from the current domain. |
Export Selected Device IP |
Export the IP addresses of the selected devices to a CSV file. |
Add to Device Group |
Add the selected devices to a device group. |
Clear Results |
Clear the live access results for the selected devices. |
Clear All Results |
Clear all the live access results in the table. |
Export Results |
Export the result of the current tuning process to a CSV file. |
Load Last Results |
Load the last result of tuning live access, supplemented by the table result of network discovery if the tuning result is not complete. |
Lock Shared Device Settings |
Lock the access credentials in the Shared Device Settings to protect them from being changed by discovery, benchmark, and other live access processes. |
Unlock Shared Device Settings |
Unlock the access credentials in the Shared Device Settings. |
