The Restore to Previous Monitor Data View button will become available under the Monitor tab after you enable Monitor Data View and then apply a dynamic data view or static data view. Clicking Restore to Previous Monitor Data View, the map will demonstrate the previous Monitoring Data View accordingly.
Viewing Customized Data Unit in Monitoring Data View
Viewing Flash Probe and Monitoring Variable in Monitoring Data View Pane
