To avoid any further dataset changes or data corruption while reinstalling MongoDB/Elasticsearch binary files or restoring MongoDB/Elasticsearch data, stop the relevant services.
1.Log in to the Windows servers where NetBrain applications are installed and stop the following services in the Task Manager.
Tip: If you have deployed a Worker Server cluster or Web API Server cluster, stop the services on each node.
Note: If the system was upgraded from the versions older than 7.1, ensure the service named proxyserverie no longer exists in the Services tab of Task Manager; otherwise follow the steps here to uninstall the Proxy Server before proceeding with the upgrade procedures.
NetBrain Component
Service Name
Web API Server
W3SVC
Web API Server
WAS
Worker Server
NetBrainWorkerServer
Front Server
NetBrainFrontServer
Task Engine
NetBrainTaskEngine
Front Server Controller
NetBrainFrontServerController
Service Monitor Agent
NetBrain Agent
Knowledge Cloud Proxy
NetBrainKCProxy
