An asterisk marked with the map name (
) indicates that there are unsaved changes on your map. To save your changes on a map:
1.Click the
icon on the map toolbar.
Tip: You can also press the Ctrl + S keys on your keyboard. For the map which you don't have the editing rights of, you can click Map > Save As to save the map as a new one in which some data cannot be stored, such as data views, and runbooks.
2.Select a folder to save the map, and then enter the map name.
Tip: The files saved under the Private or Desktop category are only visible to yourself. To make a map file visible to all users in the domain, save it under the Public category.
3.Click OK. You can view the saved map file in the Files pane.
Tip: For detailed data that can be saved in a map file, refer to Managing Map Data.
