1.Click the icon from the quick access toolbar. By default, the latest ten events are listed in the drop-down list.
2.Click the icon to launch the Event Console.
Tip: For how to quickly find your concerned alerts, refer to Event Filter. To understand each event, refer to Event Attributes.
3.Respond to an event from the right-click menu.
Acknowledge — acknowledge the receipt of the event. The count of the event will be reset to 0.
Close — close the event when the problem that resulted from the event is resolved. If the event occurs again, a new record will be added to the list.
Delete — delete the event from the Event Console. If the same event occurs again, a new record will be added to the list.
Copy — export the event into an MS excel for the archive.
View Resultshow more details to locate the event, such as opening the corresponding dashboard or map page that contains the event, or even more drawing the path calculation result or applying the data view generated by the relevant Qapp on the map.
