Splunk App - Triggered Automation (ISP Multi-Domain)
The NetBrain Splunk App is created with the idea that enabling triggered automation between Splunk and NetBrain should be an easy, self-service function. Once the NetBrain platform is integrated into the Splunk Alert workflow using the application, the customer’s NetBrain User(s), Network Operations Center (NOC) resources, and Network Engineering team will be able to reduce the Mean Time to Repair (MTTR) by taking advantage of some key features:
Enrich Splunk Alert Actions with the capability of triggering NetBrain Automation tasks.
Capturing the “Crime Scene” quickly in a dynamically generated NetBrain Map.
Creating an overall reduction in Mean Time to Resolution (MTTR) through resource collaboration in a single data
source.
Offline Installation
Connecting the Splunk Instance to NetBrain
Creating Your First Triggered Automation
Review the Triggered NetBrain Map
Logs for Debugging
