What is the certificate requirement for NetBrain?
How to make sure your private key file meets the requirement?
How to make sure your cert chain files meet the requirement?
How to verify if your certificate chain fits the bill?
How to convert the certificate to formats NetBrain supported and What is the difference between X509 and PFX?
How to find out the root cause when your SSL installation fails?
If the above FAQ cannot resolve your problem, please collect the whole logs folder under Elasticsearch installation directory and send to NetBrain Support Team.
[root@localhost home]# cd elasticsearch/
[root@localhost elasticsearch]# ls
bin config data fix_releaseinfo.json lib LICENSE.txt logs modules NOTICE.txt pid plugins README.textile temp
