The document exported from a map contains topology map, device configuration, data table and so on.
1.On a map, click Map > Export > Word from the map toolbar.
2.In the Export to Word dialog, enter a document name and select a location.
3.Click Export.
Tip: Click Advanced Settings to customize the Word template (such as logo, author, and company name) and the content contained in the document. See Content Settings for Exporting Map for more details.
4.To find the exported document, click Files on the taskbar and locate the folder where you save the document.
