1.Click
,scroll down and select Proactive Automation Manager from the menu.
2.To enable/ disable installed automations:
•Navigate to Triggered Automation tab, check/ uncheck to enable or disable installed triggered automations.
Note: If the installed triggered automation is disabled, it will not be executed in the system backend thus will not be displayed in Decision Tree.
•Navigate to Recommended Automation tab, check/ uncheck to enable or disable installed recommended automations.
Note:If the installed recommended automation is disabled, it will not be displayed in Decision Tree.
