The system provides the capability to record user activities and operations for auditing purpose. By default, this function is disabled.
To enable the function, do the following:
1.Log in to the System Management Page.
2.On the Advanced Settings tab, select the Enable Audit Log check box, and specify the retention period.
3.To view detailed audit logs, go to Home Page > Audit Logs.
Tip: You can enter keywords in the following columns to search audit logs: Username, Machine Name, IP Address, and Message.
