You can delete empty container sites (do not contain any leaf sites) or clear all sites in your domain.
Note: If you delete a container site, all its leaf sites will be deleted.
Deleting Empty Container Sites
2.In the Domain Management page, click Site on the Start Page or select Operations > Site Manager from the quick access toolbar.
3.In the Site Manager, right-click the My Network node in the site tree and then select Remove Site without Leaf Site from the drop-down menu.
Clearing All Sites
3.In the Site Manager, right-click the My Network node in the site tree and then select Clear All Sites from the drop-down menu.
