1.Click
,scroll down and select Feature Intent Template.
2.In Feature Intent Template Manager page, hover over the desired folder.
3.Click on
, and select New Feature Intent Template.
4.Define the Feature Intent Template in the Define Template Tab.
A Feature Intent Templates typically consists of the following components:
•Device Matching Logic
•Automation resources to be created
•Automation resources execution
5.Click Save after defining the Feature Intent Template.
