To configure the base URL of the IE system and portals, do the following:
2.Select the Advanced Settings tab, go to the Site Configuration area and set the base URL.
▪Website Base URL — the base URL via which you access the IE system.
Note: Webite Base URL must end with "/".
▪Portal Base URL — the base URL via which you access a portal.
Note: Portal Base URL must end with "/".
3.Click Save.
