If you want to change your password after you have logged in, do the following:
1.Click the icon on the quick access toolbar, and select Change Password from the drop-down menu.
Note: If the Change Password menu is not visible, you need to contact your NetBrain administrator to change your password or authorize you to change your password.
2.Enter your old password and new password. Click Save.
