Built-in Module Properties
The following table lists the module properties (case-sensitive).
Property Name
Display Name in Device Details Pane
Description
name
Slot#
The modules of a device.
type
Module Type
The port counts of a module.
ports
Ports
The module type of a module.
sn
Module Serial Number
The serial number of a module.
hwrev
HW Rev
The hardware revision of a module.
fwrev
FW Rev
The firmware revision of a module.
swrev
SW Rev
The software revision of a module.
descr
Description
The description of a module.
