Add NetBrain Alert Action to a Splunk Alert
Follow the steps below to add NetBrain alert action to a Splunk Alert:
1.Open an alert.
2.Click Edit to open the edit panel.
3.Click +Add Actions.
4.Select NetBrain Automation - Device.
5.Fill out the NetBrain Automation - Device Alert Action form.
Splunk token is supported to pass alert data as variables in the Alert Action.
Example:
oAlert Data Sample
    "device":"US-BOS-SW1",
    "Message":"This is a sample event message."
oToken Syntax
$result.device$
6.Click Save.
Note: The setting or trigger parameters in Splunk alert action will overwrite the same parameters in the NetBrain API Stub setting. The rest of the API Stub setting will remain.
