The Other Change node provides note function to remind the change executor to do some operations, such as discovering new devices to the domain, removing devices from the domain and updating modules beyond the change management task.
1.Point to the Define Change node and click the
icon.
2.In the Select Action dialog, select Other Change on the Network Change tab.
3.Enter the descriptions in the Description field.
Tip: You can mark the Other Change node as Completed when it is approved. Then it will be locked and cannot be edited anymore.
