R11.0a-March2023
Select Intent
You can select intents by checking the check box of the NITs in the left pane and the devices. The compound intent under the Selected tab is automatically generated based on the selected NITs and devices.
Tip: You can select/deselect all the NI items from the Hamburger Menu.![]() |
Note: The same commands from different NITs will not be merged but will still be listed in the Selected pane one by one. |
