Manually Decode Intent by Decode Now
You can click Decode Now to start intent decoding right now. Then the baseline data of qualified devices of this intent will be decoded.
Note: The process may not start immediately after you click Decode Now. The task is sent to the Front Servers and will be started within 15 minutes. |
The results of intent decoding may be treated differently depending on whether you have selected an intent timer for this NIT.
- If no intent timer for this intent is selected, the intent baseline data will be saved in the default intent timer.
- If the intent timer for this intent is selected, the intent baseline data will be saved in the selected intent timer.
As NIT is installed in the intent library, the intent will be subject to initial decoding. If the time of initial decoding overlaps with the time of Decode Now, the system will treat the two operations differently.
Example:
Case 1: If you click Decoded Now before the initial decoding is started, the two operations will be combined, and the baseline data decoding will be executed only once. The final results of this baseline data decoding will be updated to the intent timer you set up for this intent (intent timer “Weekly Friday 6PM”).
Case 2: If Decode Now is initiated when initial decoding is already in process, the Decode Now process will be scheduled to run during the next period.
- Initial decoding is performed, and the results of initial decoding are updated to the default timer.
- The Decode Now process will be performed during the next period, and the results of decoding now will be updated to the intent timer you set up for this intent (intent timer “Weekly Friday 6PM”).
