R11.0a-March2023
Define the Triggered Condition
The triggered condition defines when this Diagnosis will be executed.
Example: You can select Device Health Check from Virtual Incident Types. All incidents belonging to this virtual incident type can trigger associated intents to run for diagnosis or mapping.
- Select Virtual Incident Type to trigger Diagnosis.
- Select an incident type, such as Device Health Check.
- (Optional) Define the filters.
- Select a data field of the Incident Type
- Select an operator (contains, does not contain, matches, does not match, is not null)
- Enter a keyword
You can combine multiple simple filters with the standard Boolean AND/OR operations.
