2023-Nov-03-R11.1a
Setting Up Combined Access
As shown in the diagram below, monitored accounts on the right-hand side are the accounts you will add to NetBrain for management purposes. You will need to configure the proper roles for these accounts to be accessed by the gateway account.
Compared to pure role-based access, the combined access gains access to the gateway account through key-based access, which gives you the flexibility to set up the Front Servers in any desired location.
Follow the steps below to set up the combined access:
